1941 philco model 608p
i have a philco model 608p with the beam of light and recording unit.  i just spent a fortune have the phonograph repaired. they could not repair the recording unit so it just plays records.  any way its not working so have to contact them.  aside from this i have two wires that are not pluged in any where and while there isnt much to these things. i cant find a place to plug the wires into anything. any help would be appreciated..  one wire is heavy with three prongs and a tab. comes from under the turntable.   the other is a single wire comes from a box attached to the upper left side of cabinet.  no clue where these go.
Eico 232 VTVM Schematic
