GE model J-805 radio
They are not wooden. They are highly marbled plastic.
Bill Cahill
"If it lights in the dark and leaves you with a warm glow it's tubes."
"Honey, did you warm the baby bottle on my 75 watt hi-fi again?"
"I left it somewhere, but, where?"
There are currently 6400 online users. [Complete List]
» 2 Member(s) | 6398 Guest(s)
