SC and Philco from CL
$40 got me this clean working 1939 SC 430H nine tuber along with the innards of a Philco 630 and a suitcase full of pulls. No 45s but four 80s and a 99 so far. Can anyone tell if the 630, code 121 is a '35 or '36?
[Image: http://i150.photobucket.com/albums/s92/u...0_0778.jpg]
[Image: http://i150.photobucket.com/albums/s92/u...0_0780.jpg]
Sounds like a good haul to me, even if there are no 45's. Icon_thumbup There's got to be a chest full of 45's out there somewhere. Thar be good booty if one of us find it. Ar! Icon_lol
The 630 is a 1936 model, introduced June 1935 as a 1936 model; and it looks like this is what you have, the remains of a 630X console.
Congratulations on your finds!
Thanks Ron. I wish they had made the oval lens for a longer period. IMO it looks better than the later round ones.
Oh well, I do like them all.
Nice job!! I've got my eye on a model 645 that's at local and is at a second hand store. At the end of the month everything goes for 1/2 price. Makes it a good deal then. Like I need another radio. Your dial on the SC looks just like the one on the console set I had back in the '60s
Philco 91 Tuning Condenser
There are currently 9397 online users. [Complete List]
» 3 Member(s) | 9394 Guest(s)
