Philco parts
To what model do these tuning parts go? The chassis was so rusted, I could not identify it. I am guessing 640 or 650 series, but I am not sure. any help would be great.....
.....i have learned these are from the 640. what are these parts called? does anyone know?
Eico 232 VTVM Schematic
There are currently 9142 online users. [Complete List]
» 1 Member(s) | 9141 Guest(s)
