Philco chairside completed
I picked this little gem last fall , and during the winter I did the chassis.
          It had all the original Philco tubes, Ron had sent me some safty caps to complete the job.
 It has a very clear sound and plays very good.
    I just finished the cabinet.    It was all there,  and after stripping  the cabinet I used Grain filler on the top,
then several coats of lacquer.
   This is the first chairside i have seem in person, and I think i like it
 Dan in Calgary
   Living in Calgary Alberta
Hello Dan,
that set looks outstanding it is a really nice design too far as the cabinet goes !
Something like that would look right at home in my Living room .
Definite man cave item! Nice work, Dan! Take care and BE HEALTHY! Gary
Very nice!
Great job as always, Dan. Icon_thumbup
One of the nicer styles of chair-side radio I've seen. Nice work !!
A 38-15, is it?
Yes it is a 38-15.
 The radio is actually a little darker than the photos.
  Next time I will use a tripod and no flash.
 Dan in calgary
Eico 232 VTVM Schematic
There are currently 8766 online users. [Complete List]
» 2 Member(s) | 8764 Guest(s)
