New Acquisition Philco 89B
Most of you probably saw this on Ebay last week.
[Image: http://i985.photobucket.com/albums/ae335...5_0062.jpg]
[Image: http://i985.photobucket.com/albums/ae335...5_0063.jpg]
[Image: http://i985.photobucket.com/albums/ae335...5_0064.jpg]
I bought it for $26.03 and shipping. The cabinet is a little rough, but I think I can save it. The chassis is pretty clean, but the speaker has a repairable hole in it. It has a nice looking globe rectifier, but one plate test very low on emission and indeed I can see quite a bit of the oxide coating missing from one of the filaments. Icon_sad Hopefully this will be a next winter project.
M R Radios   C M Tubes
Hey Steve, congratulations on your acquisition! Icon_thumbup If anyone can fix that cabinet, you can.
We'll all be looking forward to the "after" pictures whenever you do get it completed.
Hi Steve,
I saw that one too and gave a hairy eyeball. The price was right but I've got bunch of those kinda projects. The 89 is a great little player. I like the other style cathedral cabinet a bit better.
Good luck w/it
That's a great buy, especially when we all know what kind of showpiece you will turn it into. I am looking forward to the before and after pics.
BTW for all of you new Phorum members, Steve is a master at refinishing AND rebuilding radio cabinets. I had him basically make a new cabinet for my Philco 43 and it is absolutely beautiful!!!
Strongly recommend you contact him if you have any cabinet resto that you want to have done RIGHT!
