Philco 116 chassis
I picked up what was advertised as a Philco 116b chassis.  The layout seems a bit different in the back as far as the electrolitics and the ant grd terminals.  Could this be a 116X chassis is there a difference between the 116 chassis?
Philco's
86 Low Boy     71B      42-321T
90 High Boy    52B      46-1203
95 High Boy    118B     48-214
112X Console     60B       48-206
118X Console     84B       49-506
41-608P Console   610B   76 High Boy
41-265 Console   37-89B   370LZ
52GC                38-35B
20 Baby Grand   38-10T
70 Baby Grand   41-221CI
Yes you hit the nail on the head it's a X chassis. You can tell by the 4 pin tube sockets (you got too many of them). And the power transformer is bigger. The X uses 4pin output tubes (6B4's).
Devil in the details...
Thanks for the assist.   At least I now know what kind of cabinet and speaker I need to start looking for.
Philco's
52GC                38-35B
I'm not sure but I've not seen one with that switch by the shadow meter. I have both the X and B models. That chassis might be from a PX that's a 116X w/phono in the top. Pretty low production numbers. Jeff W out in California has one.
That switch looks like something added by a repairman or "restorer" years after the set was built.
The chassis had paperwork for the switch install, so I agree with Ron I think it was an add on by someone later down the road.
Philco's
52GC                38-35B
Philco 91 Tuning Condenser
There are currently 8516 online users. [Complete List]
» 1 Member(s) | 8515 Guest(s)
