Philco 42-380 safety cap
Agree with all , but I would not bet my life on the fact that the outlet you plug into is wired correctly. Just be careful!
Okay, now I understand " safety caps" They are somewhat misleading but I guess there a good idea anyway as they fail open. thank you to all the replies on the subject.
I've said it more than twice, here and there, but don't ever bet your life on a 3 prong outlet, polarized cord, or anything else prone to human error (including my own.)
Agreeing with codefox.
Unless you have tested them, consider they might be wrongly wired. In my house, most of the ones in the basement had to be rewired;
some had hot & neutral reversed.
some had no ground
some I still don't understand what they were trying to do when they wired that.
Now, without betting your life on it, having safety measures can't be as worst than having none.
-Mars
I like moving the line capacitors (electrically at least) to the radio side of the power switch. Whether they are "safety" capacitors or not I don't think that it's wise leaving any component with full line voltage across it any time while the set is plugged in. Zenith was doing this right into the 1960s, it is a practice that was never allowed by the electrical code in Canada along with hot chassis AC/DC sets.
So, by the code in Canada, the line filters shouldn't be "always connected" but placed "after the power switch"?
(it makes sense, less power wasted for "waiting")
-Mars
Philco 91 Restore Code ??
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 5506 online users. [Complete List]
» 1 Member(s) | 5505 Guest(s)
