41-265 knobs
Just purchased a 41-265 my first philco.and my first tube radio.  It is missing a couple of the knobs. I've look on eBay does anyone know of a good source for these. Also
Is restringing the dial.a difficult job.  Thank You in advance
Welcome to the Phorum!
Icon_wave
Dial stringing can take some patience, long tweezers or forcepts, a few swear words but with some practice it is not too hard. The dial string diagram for the 41-265 is found on the schematic info (seen in our library): https://philcoradio.com/library/download...20Book.pdf
Check with the knob vendors found on our resources page: https://philcoradio.com/library/index.ph...tegorized/
Renovatedradios.com has reproduction 1941 knobs but looking at our gallery photo and some others images I googled I don't think they match what was on the 41-265
and lastly, put a Wanted Ad in the Wanted Ad section and someone might have some in their odds and ends stash..
Welcome and feel free to ask any questions. There's a lot of expertise here. I find a spring hook really aids in dial stringing along with patience, a few chunks of masking tape and patience.
Thank You for your suggestions.
I’m entering a whole new world and looking forward to it.
Hi,
It appears that your 41-265 uses the same knobs as were used on most 1937-1940 Philco radios.They are dark brown in color, and quite common.
As Bob (klondike98) mentioned, one of the knob vendors will likely have a set at a reasonable price.
Renovated Radios used to sell these as reproductions, but they are no longer available. But that's ok, as originals are, as I mentioned, pretty common and easily found.
Hi
The Philco p# for the knob is 27-4332 w/pointer and 27-4225 w/o pointer. I just mention this encase you find a vender that uses oem p/#'s. These are brown knobs. There are black ones but they are for the 1936 models (yours is a '41 model). They where used from '36 to about '41, they're pretty common. You would use the pointer knobs where there are decals on the front panel to select a choice. The tuning knob wouldn't.
Give Julie McCall a try:
radiopup@bellsouth.net
ps Ron types faster than me...
Icon_lol I don't know about that, Terry...
I looked at the 41-265 service data in the Philco Library, and the part number for the knobs is - 27-4332. So all four had the molded-in pointer, which I thought was correct for most Philcos made after 1938.
Philco 91 Tuning Condenser
