Philco Chassis Batch and Factory Codes
I posted this as part of another thread- is anyone familiar with chassis batch codes?  My 38-690, code 125, says "14"- does that refer to the week of production?  Going from June 1st, 1937?  Also, cabinet is stamped with a "19", which I understand to be the Maddox Table Co.  Did they build all of the 38-690 cabinets?  Just curious in Michigan.....
