Philco Dial Pointer
Does anyone sell original or reproduction Philco dial pointers?
For....
You can try posting a Wanted Ad to see if someone has one in their parts drawer. I also found this site that has some that depending on the model you are asking about might work.
https://www.antiqueradiosandparts.com/in...y&path=473
Thanks, I have already posted a want ad with no response. The pointer I need is for a model 39-6.
Don
Hi Don,
You might want to check the gallery for similar sets like the 38-12 and several others along with the '39 ones. The ones I've worked on I've almost needed dynamite to the pointer off. You can double check the part# to be sure. To me they all look the same. Give Julie McCall a try.
Thanks, who is Julie McCall? How do I reach her?
Don
https://musiccityvintageradio.wordpress....ty-mccall/
Address is in the last paragraph.
Her email address is in our library resources section under knobs:
https://philcoradio.com/library/index.ph...tegorized/
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
Where do I look? 7B7 Suppressor? Both these radios seem to connect the SG to AVC. Which I am not sure why, but then ...morzh — 06:27 PM
