Philco Dial Pointer
Does anyone sell original or reproduction Philco dial pointers?
For....
You can try posting a Wanted Ad to see if someone has one in their parts drawer. I also found this site that has some that depending on the model you are asking about might work.
https://www.antiqueradiosandparts.com/in...y&path=473
Thanks, I have already posted a want ad with no response. The pointer I need is for a model 39-6.
Don
Hi Don,
You might want to check the gallery for similar sets like the 38-12 and several others along with the '39 ones. The ones I've worked on I've almost needed dynamite to the pointer off. You can double check the part# to be sure. To me they all look the same. Give Julie McCall a try.
Thanks, who is Julie McCall? How do I reach her?
Don
https://musiccityvintageradio.wordpress....ty-mccall/
Address is in the last paragraph.
Her email address is in our library resources section under knobs:
https://philcoradio.com/library/index.ph...tegorized/
Philco 91 Tuning Condenser
There are currently 9307 online users. [Complete List]
» 1 Member(s) | 9306 Guest(s)
