Tubes for the Philco 41-608
Can anyone tell me the complete list of tubes needed for the Philco 41-608?? The label on the back is hard to read and I want to have some for back ups. Thank you!!! Happy Holiday everyone! Icon_biggrin
Hi Jenny
Here's the tube layout for your 41-608:
[Image: https://philcoradio.com/images/phorum/Ph..._tubes.jpg]
thanks Ron...you are the best!!!! Happy holidays!
Jen 8)
Hi Ron!
Would you be able to post that attachment to me as well? For the Philco 41-608 tube list? I cannot open the one attached to this thread?
The picture above has been fixed.
A reminder: You may find any prewar (and some postwar) Philco service information you may need, all for free, in the Philco Library:
https://philcoradio.com/library/
No membership fees. No restrictions. High resolution scans.
Thanks so much Ron and I will remember that in the future!
There are currently 9180 online users. [Complete List]
» 2 Member(s) | 9178 Guest(s)
