Philco 40-155
Acquired this radio without a back cover or loop antenna.  Trying to locate any information of what the antenna is, size, how many turns of wire over the loop frame and where the taps are since there are 4 connections on a terminal strip on the back of the radio.  It does have the shortwave antenna still in the top of the cabinet and I believe that connects to terminal 3.
Eico 232 VTVM Schematic
