candohm section wattages
I have a Philco-model 41-255 which has a three section candohm in it; however, no wattage for each is not shown. Any clues would help as far as replacement, if needed. Thanks
Welcome to the Phorum chradios! Are you referring to part 61? The schematic and other information is available in the Service Section of the Philco Radio Library, service info accessed at the bottom of the page. https://philcoradio.com/library/index.ph...year-book/
Take care and BE Healthy! Gary
YOu could do rough assessment.
You need to know the current. The assumption is that the current through the choke is the same that goes from the Ground back to the centertap of the rectifier.
The dropout across the choke is 85V at 1100 Ohm, making it 77mA. Let's make it 80 mA.
The total resistance of the "Candohm" is 192 Ohms. This makes it 1.14W total.
The dissipation on the sections is proportional to their resistances, so it will be 0.87W, 0.18W and 0.09W respectively.
Now triple the ratings: 3W, 0.5W and 0.25W for 146, 31 and 15 Ohms respectively. These are the ratings for the sections. Of course you could use large ratings. I usually go for triple where the circulation is good and no combustible material is nearby.
Can I use Metal Film resistors for the 2 lower wattage on the candohm?
hello Chradios,
Yes you sure can use metal film resistors !
just make sure to give your self enough over rated wattage that way it will run cooler and last longer .
Rich meant resistors.
As he said, you could use any whatsoever. As long as the wattage is appropriate.
Hello Morzh ,
Yes I editted my post to resistors .
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
Where do I look? 7B7 Suppressor? Both these radios seem to connect the SG to AVC. Which I am not sure why, but then ...morzh — 06:27 PM
