How do I figure what antenna to use
Hi all
I have a Motorola tuner, Icon_surprised. The antenna is missing. Icon_sad I know it had a ferrite rod type of antenna Icon_confused. Now the question Icon_rolleyes to replace the ferrite rod how do I figure what uH I need Icon_confused:. Can anyone help me Icon_wink. Antique parts has three 230 uh, 250uH and 650 uH. HHHHHHHeeeeelllllppppp. Joe
The 230 or 250 should work. The winding can be slid along the rod to adjust the inductance as part of the alignment.
Ok I will try the 250. Thanks for your reply Icon_wave . Joe
Philco 91 Tuning Condenser
There are currently 8058 online users. [Complete List]
» 2 Member(s) | 8056 Guest(s)
