New Project: 1934 Colonial 662 (corrected model)
Threads: 44
City: Menlo Park
State, Province, Country: CA
Lots of work on this set this weekend. First off, to diagnose the oscillator problem. I replaced all the paper caps, and the suspect 50k resistor, and the paper caps. Still no stations, and now there was an LF instability in the whole set as soon as the tuning cap was more than half open, with the set blowing raspberries from the speaker. At the end of the day, I returned to checking wiring and component values from the schematic, and found a broken wire from the converter tube grid circuit to the oscillator section of the tuning cap. OK, something to go on, and a good end to the day.
Today I removed the tuning cap, which was needed anyway, to replace the rubber bushings. I punched these out of some silicone foam, and added new wires to the cap #28 enameled wire, with cloth insulation slipped over it was a close match to the original. With this, I finally had some reception, but still a very unstable receiver. Whistles on stations up to about 100 on the dial, after that raspberries from the speaker, on either band. Eventually I tracked this to a bad solder joint connecting one of my restuffed caps. With that restored, I was able to align the radio and it really pulls in stations.
Pics tomorrow,
Ed
Threads: 44
City: Menlo Park
A few pics
Fine wires leading to the tuning capacitor stators. Notice the osc section on the left has a broken connection. These had so little spare that the breakage was probably due to the additional movement due to the perished rubber mounting grommets:
New grommets cur from silicone foam rubber:
Tuning cap with new wiring, ready for reinstallation.
Playing some music
Threads: 11
City: Greenlawn
State, Province, Country: NY
Nice and clean! Looks GR8!!
Threads: 44
City: Menlo Park
This weekend. I found time to restuff the two electrolytic cans. All is still working nicely. The chassis is waiting for a new line cord, still to be delivered, and will get new antenna and earth leads before returning to the cabinet.
Ed
Threads: 271
City: Wilsonville
State, Province, Country: OR
Looking great!
Threads: 44
City: Menlo Park
Another one over the finish line. I'm pleased with it and particularly enjoyed working on this radio for some reason I cannot quire explain.
Threads: 562
Cute set.
Threads: 110
City: Omak
State, Province, Country: WA
Hello Ed,
Nice little set !
Threads: 28
City: Wellborn Florida
Great job! Ed
Threads: 44
City: Menlo Park
Thanks everyone. I appreciate the kind words.
Threads: 414
City: Boston
She is a beaut. Nice size, maybe I could sneak one that in unoticed!
I think Colonial made a lot of stuff for SEARS if its the same Colonial I am familiar with.
Enjoy.
Paul B
Threads: 110
City: Omak
Hello Paul,
Yes it is the same company and I own a bunch of sears radios made by them also Arvin .
Threads: 414
City: Boston
I like that mantle style, thanks for confirming Rich.
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
Welcome to the Phorum, R3Sons! I have very limited experience with car radios other than installing custom radios back ...GarySP — 01:08 PM |
OK, I need to rename this thread to say..Eico 368 TV/FM Sweep Generator instead of the current title..Heathkit Sweep Gen...462ron — 12:49 PM |
Hello, I have a Philco (Ford) 6TPZ and a 5TPO radio. I replaced the electrolytic capacitors in both. I have the SAMS m...R3Sons — 12:29 PM |
