Model ID
Can anyone ID the model of this Philco intercomm system?  Trying to find a Drawing.
Philco's
86 Low Boy     71B      42-321T
90 High Boy    52B      46-1203
95 High Boy    118B     48-214
112X Console     60B       48-206
118X Console     84B       49-506
41-608P Console   610B   76 High Boy
41-265 Console   37-89B   370LZ
52GC                38-35B
20 Baby Grand   38-10T
70 Baby Grand   41-221CI
Thanks!!
Philco's
52GC                38-35B
There are currently 9094 online users. [Complete List]
» 3 Member(s) | 9091 Guest(s)
