Philco 38-10 faux finish?
I just obtained a 38-10 that although quite dark, the cabinet is in good shape. Is the 38-10 a model that has the faux finish? I’m not experienced enough to tell from just looking at it and I don’t want to do anything to it until I know.
Sure looks like it. I've wiped them down w/a soft cloth and oms to clean off dirt and smoking residue. And then resprayed w/sanding sealer (a few coats). Do any t/u work and respray w/gloss. Looks like new.
GL w/your new project!
Hello Phil27,
Yes it is faux finish I have that exact radio in my collection and it is my next project for a full chassis restoration my cabinet is in great shape !
Just for future reference, our library has a list of the photofinish models. See:
https://philcoradio.com/library/index.ph...otofinish/
Thanks very much. I’ll clean it up as best I can. Appreciate all the replies!
Hey Bob,
That's pretty slick! That's the trick abt the library you gotta know where to look to find the right stuff.
It's very likely dark because of layers of dirt, wax, oil, maybe even tobacco tar on the cabinet, GoJo cream hand cleaner, the non grit type, does a good job for cleaning dirt from wood cabinets, and many other things too.
Hello Phil27,
Here is a Photo of mine !
Since this photo I bought a escutcheon outer ring from Ebay this is my next project to hit the bench the chassis has not been restored yet .
I tried several methods to brighten the face up, nothing worked satisfactory for me…so I sanded off the faux finish, bought some walnut veneer and edging strips from Lee Valley and this is the finished product.
Thanks again for all the helpful input!
Looks super, very nice indeed! What time is Jack Benny on?Icon_smile.
Hello Phil27,
Looks great that what like about this hobby and this forum there so many great people here and why I see it if you are happy with it that what counts !!
