model 19
Just got done recaping and adjusting IF and trimers dosen't seem sensitive as some of my other radios with tuned rf amps is that normal for a model 19b code 126?
Should be as sensitive as your other radios. Start by checking the voltages on the tube pins, etc for anything out of range. May have a really weak tube somewhere. Signal injection may be needed if all else fails. Richard
And don't forget those coils...they usually have, or develop, open primaries.
A model 19 should be a very sensitive, very good performing radio when properly restored. If you don't need a lot of audio power but want good sensitivity and selectivity, a model 19 or 89 is an excellent choice for a vintage radio.
Already rewound two of the coils could be a weak tube tried the 80 and 42 out of my 84b no change don't have any 44 or 36 tubes to try radio works about like a good 5 tube radio like say a 37-610 but not as good as my sparton 1466 or GE SR II. I may buy a 36 and two 44 tubes to see if that helps
Thanks
You could buy a tube tester.
vinzer Wrote:Already rewound two of the coils
Let's address that. How closely did you replicate the originals?
Used to have a tube tester but gave it away last time we moved.
Counted the turns and wound them the same way as they were.
vinzer Wrote:Counted the turns and wound them the same way as they were.
Same wire gauge, same winding length?
used same wire I used on a model 84 looked about same but don't the size.
Radio works ok just thought it could be a little better.
Your windings may not be phased correctly; try reversing the leads to your rewound coils.
Before you buy more tubes, measure and record the voltages on your tube sockets and get back to us with the results; it can probably be narrowed down to a single component with voltage data.
Do you have an oscilloscope? It will tell you quickly if your oscillator is running- and often it isn't.
I love my 19; it's my most used radio at present.
Pete AI2V
I will check the voltages phase of coil wires and see what i find. Radio works so oscillator is running.
Checked voltages found them all low . The lug that goes between the cardboard and filter cap was shorted to ground. Works much better now. Thanks for all the help.
91H Code 126 Restore
Philco 70 antenna lead
