Philco 3650/650 Tuning Mechanism
Hello, I need to dismantle the tuning mechanism in my 3650 (Canadian). I have removed the dial screen but can't figure out how to remove the shadow screen. The picture shows how far I have gone. Also the band selector has a set screw (red circle) that seems to be fused in place. Tried Liquid Wrench having no luck.
Dan
Perhaps this will help  Dial Drive Rebuilding – Models 116, 640, 643, 645, 650, 651, 655, 660, 665 – Philco Library (philcoradio.com) Some set screws can be tough to remove. A good fitting screwdriver is a must with straight blade not rounded on the corners. You can try holding a hot soldering tip on the offending screw. I'm pretty sure that the part is mostly pot metal so if you want to use a torch be careful not to melt it.
Thanks Terry. The link was just what I needed. I'll give the hot soldering iron a try.
Dan
Just as I thought I am missing the dial pointer shield. Any idea where I can get one. Did not find one at Radio Daze. Mine would have 4 arrows.
Philco 91 Restore Code ??
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 5721 online users. [Complete List]
» 1 Member(s) | 5720 Guest(s)
