aux input on 40-180
hello everyone! i have been reading your forum for quite a while and have now run into something i could use your help with. i am in the last stages of restoring a gorgeous 40-180 and now would like to run a discrete aux input so that i can plug an ipod into it and enjoy period correct tunes from it. what is the best way of doing so? i apologize if this topic has already been covered. if it has i must have over looked it. thanks for reading and for any helpful replies!!!!
Hello and welcome!
Yes, this subject has been covered before; please follow this link to find the thread.
http://www.philcoradio.com/phorum/showth...p?tid=2095
Good luck.
Eico 232 VTVM Schematic
There are currently 9822 online users. [Complete List]
» 1 Member(s) | 9821 Guest(s)
