Can anyone Identify this radio
Greetings,
It has no identifying marks on it anywhere. A few of the tubes say philco. But I dont recognize it.
Any help would be appreciated.
Cheers
Current Restorations In Process
RME DB22A - Lafayette KT200 - Hammerlund HQ 140 XA
Johnson Viking II - Viking VFO 122 - Johnson Ranger
Philco Model 90 Low Boy
I got stuff.... and things.... and I never said I could spell!
If it is not an Echophone, then it is a Peerless.
Heres a shot of the Chassis....
Quote:If it is not an Echophone, then it is a Peerless.
Still not seeing a match with those either... but thanks!
Cheers
Im begining to think someone used a Peerless reproducer cabinet to house another RF deck of unknown origin.
It clearly seems its a Peerless cabinet.....
Cheers
I think it is an Echophone or similar chassis in the Peerless speaker cabinet.
Would a Peerless speaker be deep enough to house a chassis? It's not an Echophone cabinet because there is no lyre (sp?) On the grill.
The chassis almost looks like an Aztec by Fred Stein, but it isn't painted black and doesn't have the brass sn tag.
Heres a shot under the chassis.
It is an odd case isnt it??
Cheers Icon_smile
John
The Grill and the shape of the cabinet are 100% Peerless speaker.
Whether they deepened it to house the chassis....good question.
It is a Franken Radio for sure.
What are the tubes currently in the chassis? Interesting that the one tube socket on the far right is installed with screws while the other 4 are riveted. Stuffs been done to this radio. Take care and BE HEALTHY! Gary
Quote:What are the tubes currently in the chassis? Interesting that the one tube socket on the far right is installed with screws while the other 4 are riveted. Stuffs been done to this radio. Take care and BE HEALTHY! Gary
Left to right - 24A 24A 24A UX245 80
Cheers Icon_smile
Another photo of the top..
I took that tube list to Antiqueradios.com and got 8 hits for a 5 tube radio, none that look like a match. Looks like you have a chore to Name That Radio!
Thanks to all who helped.
Really appreciate it.
Cheers!  Icon_cool
Eico 232 VTVM Schematic
There are currently 8532 online users. [Complete List]
» 2 Member(s) | 8530 Guest(s)
