Hello philco4me,
If it were me I would use 10-10-22-
I would use the 22 in place of the 16. 40 is overkill.
Thank you all very much for your help.
I have a 25 at 450volt. Will that work ?
Sure.
Thank you very much.
Is the power switch replaceable ? If so what is the replacement ?
[/url]
Hello Philco4me ,
Contact Mark Oppat's site he sells and rebuilds controls plus other parts that he sells too.
[url=https://www.oldradioparts.net/]https://www.oldradioparts.net/
Thank you. Also where is the arm set down adjustment on the idler wheel BOL turntable ?
