My latest restoration Sony TR-610
Hello Everyone,
Here is my latest restoration My little Sony transistor radio model TR-610 from 1958.
I had replace what I consider to be the smallest multi-section electrolytic capacitor this little tiny capacitor contains three 20 ufd at 10volts .
the one thing I have to do is to adjust some trimmers on the tuning capacitor because I noticed the factory seal was broken but the IF cans are still sealed .
P.S. I will post a photo of the capacitor too.
Rich
They forgot to add the word "whopping" in front of the "six transistors" Icon_lol
Multi-section cap...wow, have never seen one in small transistor jobs. Do you have photos?
Hello morzh,
Here you go the capacitor is 1/2 tall and like 3/8 inch in diameter .
Sincerely richard
Nippon Chemicon made I think, probably constructed like a jelly roll inside, much like a multi section twist lock can.
Hello Arran,
Yes , I am sure it is a Nippon Chemicon made capacitor !
There are currently 9474 online users. [Complete List]
» 1 Member(s) | 9473 Guest(s)
