As Promised: Companion for 84B
I just figured out how to work my replacement camera from CL. A smaller LCD than my broken Kodak, but easier to figure out. A Sony DSC-W230 if anyone is curious.
I couldn't resist this local pick-up even though the style is what I would normally run screaming from. But since it's a radio...
[Image: http://i150.photobucket.com/albums/s92/u...C07369.jpg]
So now when you get hungry, you can help yourself to some cookies from your neat new "radio" cookie jar while you enjoy listening to your Philco 84B! Icon_wink
I don't think I've ever seen one in that style before.
You need to hunt up a "Philco Cookbook" cookie recipe.
Chuck
Hunt successful.
[Image: http://i150.photobucket.com/albums/s92/u...FG2583.jpg]
Boy the robo-ads sure are getting sophisticated. The instant I uploaded this pic to photobucket, an ad with voice and pics for Philly Cooking Creme popped up on their page.
Enough to make you toss your Philcos. We hear you.
There are currently 10959 online users. [Complete List]
» 2 Member(s) | 10957 Guest(s)
