Threads: 1
City: League City
State, Province, Country: TX
I obtained this little radio in Tulsa easily 40 years ago. I'm now trying to figure out what model it is, and perhaps also figure a way to restore it in something resembling original. I have not tried to turn it on, as I was told not to even think about it until the unit was checked out. Label says Chassis type 53, Code 121 which doesn't appear on a Google search, I remember being told years ago this was a late 1920's-early 1930's radio but that's anecdotal evidence only. Thanks for any help!
[Image: https://professorquicksand.wordpress.com...?w=2800&h=][Image: https://professorquicksand.wordpress.com...?w=2800&h=][Image: https://professorquicksand.wordpress.com...?w=2800&h=][Image: https://professorquicksand.wordpress.com...?w=2800&h=]
Threads: 562
Threads: 1
City: League City
Well, yeah that's what it 'says' but it does not look at all like one of the ones in the picture. I've not seen another even close to what this one looks like.
Threads: 28
City: Wellborn Florida
A link to Nostalgia Air list a 53 no 53C might just be the cabinet never worked on one. Nice looking set should be fun. David http://www.nostalgiaair.org/Resources/761/M0013761.htm
Threads: 1
City: League City
Thanks very much! At least I have a starting point.
Threads: 271
City: Wilsonville
State, Province, Country: OR
It’s a 53C as pictured in the Philco gallery (see morzh’s link https://philcoradio.com/gallery2/1933a/#Model_53C ) The top is slightly different with additional vent slots. Probably a change made during the production year. The front is missing the Philco decal probably because someone refinished the cabinet at some point. Nostalgiaair lists chassis schematics that were in the Riders schematic collection. The same chassis can go into different style cabinets for some models. The “C” is a cabinet style designation.
Threads: 268
It's an ac/dc version of the model 84. A couple of other things in the schematic struck me odd. 450kc IF? By '33 Philco had dropped the 175 and 260kc IF except for the 200X and had adopted 460kc. The use of a pm speaker on an ac set in the '30s. Philco use them in the farm set but this is the 1st one I've seen in an ac set.
https://philcoradio.com/library/download...%20149.pdf
Threads: 562
Well, look again. Specifically at the one that says "53C".
According to you, these two have no similarity whatsoever.
Threads: 43
City: Roseville, MN
Looks the same to me, right down to the grille cloth. I can even hear Nelson Riddle in the speaker. 53C it is.
Threads: 562
Rod
And it is in our own gallery.
It is the same; the grill pattern on top is a bit different, but then if you look at 38-12C radio, oh boy, do they have those galore.....
Threads: 110
City: Omak
State, Province, Country: WA
Hello airboss01 ,
That sure is 53C and that was a good find on your half .
this looks like a fun project !
Threads: 154
City: Westland, MI
I agree it's a 53C. The vents in the top were a decorative solution to the heat generated by the tubes, and the extra vents probably, as Bob said, a mid-production design change. It does look to have a cabinet in less than original condition, a previous owner's probable refinish . Looking forward to your restoration threads. All in all a nice project! Take care and BE HEALTHY! Gary
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
Welcome to the Phorum, R3Sons! I have very limited experience with car radios other than installing custom radios back ...GarySP — 01:08 PM |
OK, I need to rename this thread to say..Eico 368 TV/FM Sweep Generator instead of the current title..Heathkit Sweep Gen...462ron — 12:49 PM |
Hello, I have a Philco (Ford) 6TPZ and a 5TPO radio. I replaced the electrolytic capacitors in both. I have the SAMS m...R3Sons — 12:29 PM |
Hello Peter,
Thank you for posting that !!
Eico 232 VTVM Schematic
There are currently 10065 online users. [Complete List] » 1 Member(s) | 10064 Guest(s)
