Predicta Holiday Image Tearing at Top of Image
Threads: 1
City: Saskatoon
State, Province, Country: Saskatchewan
Threads: 562
There are couple of folks here, who are knowledgeable in TVs.
This said, at least one of them participates in Facebook's "Predicta" group, where most people are knowledgeable about the Predicta.
Threads: 8
City: S. Dartmouth
State, Province, Country: MA
Look at the vertical wave form. If caps have been replaced in those circuits there may be an issue. Check all ground connections especially if they are riveted to chassis, solder those with a large bolt iron. Be sure there is no heater/cathode leakage in the vertical oscillator and vertical output tubes.
Chas
Pliny the younger
Threads: 42
City: Chicago, IL
You set is having trouble locking after the vertical retrace interval..Have you adjusted the coarse horizontal hold and ringing coil as described in the service info? Also, looks like you might be using a signal source with macro vision copy protection
Threads: 42
City: Chicago, IL
Also what effect does adjusting the horizontal hold and contrast have?
Threads: 8
City: Roanoke
Bob Andersen Wrote:Also, looks like you might be using a signal source with macro vision copy protection.
Although I don't work with TVs a friend who buys them and sells them on the auction site has enlisted my aid in the past. He has no way to create an NTSC signal to show that the CRTs are working. What I bring for the purpose is my first DVD deck, a single-layer Sony, and a couple of old DVDs of "Burns and Allen" and "You Bet Your Life," plus an RF modulator.
Threads: 110
City: Omak
State, Province, Country: WA
Hello guys,
Yes , bob brings up a good point and that why I have macro vision copy protection union that corrects that problem this was a common problem with older tv's
I used to sell those units at my tv repairshop.
Threads: 82
City: Annapolis, IL
State, Province, Country: USA
Aaaah yeah. Macrovision. Good old “flagging “. As mentioned a filter might help. Available on Amazon. I use on on my dvd recorder. Works great! Had a similar problem on some of the older Sears sets, seems like we had to change a couple resistors in the horizontal section. About all I remember tho. Been a few days.
Tim
Threads: 1
City: Saskatoon
Thanks for the ideas everyone. I just got the chance to sit down and play with the set today, however when I powered it on there is no video at all aside from the raster. I'm going to go through and check connections in case something may have come loose while sitting somehow. There was a brief 15ish seconds where video and sound came through perfectly, but it quickly went away and I'm not even sure what happened to get that far. I will update when there is progress to report!
Threads: 82
City: Annapolis, IL
I know this thread is a few months old, but I was looking through things since I have a pedestal I'm going to play with and I noted in the 5th picture, upper RH corner there's an orange drop cap connected to pin 6 of what looks like the horizontal output tube. Is that soldered?? It looks like the wire is just wrapped around the terminal.
Tim
OK, I need to rename this thread to say..Eico 368 TV/FM Sweep Generator instead of the current title..Heathkit Sweep Gen...462ron — 12:49 PM |
Hello Peter,
Thank you for posting that !!
Eico 232 VTVM Schematic
Try BAMA for a schematic.
Var resistor id
Var resistor id
Var resistor id
Its a Sylvania 400 oscilloscope. here is a clip of r-100. Would be nice to know the current required. Not listed in part...Martinj — 02:10 PM |
Thanks Richard. I hope you enjoy it.
Here I have created an English section on the history of radio with videos in Engl...RadioSvit — 10:23 AM |
There are currently 8279 online users. [Complete List] » 2 Member(s) | 8277 Guest(s)
