Threads: 271
City: Wilsonville
State, Province, Country: OR
The following advice came to us through the webmaster email address. The poster (Vickie) could not navigate the phorum but wanted to offer the advice so here it is...
"Wanted to give advice on how to get mirror Finnish on bakelite but your website to hard to use, so tell you, my friend has a ford pop with bakelite dash,was oxidised looking old, got him to 4000 grit sand it then I polished it on my bench grinder I have two wheels one sisal, one loose calico, used blue plastic compound wax stick,came up better than new , but it takes some time as you have to keep it moving so as not to make to much heat in one spot, hope this helps restoring anyone who wants shiny bakelite"
Threads: 414
City: Boston
Interesting info, I have also heard that one must be real careful when sanding Bakelite, particulate matter.
Threads: 8
City: S. Dartmouth
State, Province, Country: MA
There are different formulations of Bakelite. These variations make it sensitive to UV, alkali, to the type filler, size of filler and amount of filler.
The most important caution in re-surfacing Bakelite is be aware when filler is reached. By molding technique, the filler migrates away from the surfaces leave the opaque resin on top. Sand through the resin and reach the filler/resin, no polish will help at that point. The solution is to use an opaque toning lacquer, at that time the desired tone can be used or a lacquer solid color paint.
The same model radio can be expected to polish in the same manner, but another model/brand may react differently, such as have filler very close to the surface.
Chas
Pliny the younger
Threads: 562
I used shoe polish.
Good enough.
Threads: 110
City: Omak
State, Province, Country: WA
Hello Guys,
Yes , I have heard people use shoe polish like Morzh talks about .
I have never tried sanding it .
Threads: 21
City: Svalyava
State, Province, Country: UkraineTranskarpatia
I have used Tempo automotive wax paste made in the Czech Republic several times and have had excellent results. Before polishing, you need to sand with fine automotive abrasive paper size 1000, then wash, dry and polish with Tempo wax paste. The protective wax layer will keep the shine and great look for a long time
Old Tube Radio Online Museum / Музей ретро радіо
https://www.youtube.com/user/RadioSvit?d...lymer=true
Sincerely Peter
З повагою Петро
(This post was last modified: 06-07-2024, 02:40 PM by RadioSvit.)
Threads: 110
City: Omak
Hello Peter,
Glad to hear from you and Yes one the groups on facebook that I am part of one the members has auto detailing business and he also uses car wax and buffer to bring the shine back !
Threads: 28
City: Wellborn Florida
Have used armor all the stuff for making tires shine. David
Threads: 110
City: Omak
hello David,
I have never used that before I have General Electric radio that will need a lot polishing is finish is flat and has streaks too .
Threads: 28
The armor all just soaks right in the bakelite. David
Threads: 8
City: S. Dartmouth
Quote:The armor all just soaks right in the Bakelite.
The surface has been "cleaned" in the past and the top "layer" is gone. Now down to the porous filler material.
A build type polish with a wax may work, if it does not then some sort of Artists, spray acrlic/sealer. Last resort but with through cleaning is opaque lacquer toner, that, will cover all sins...
Pliny the younger
Threads: 43
City: Roseville, MN
I revived a Bendix bakelite cabinet with Howard Restor-A-Finish after cleaning with 0000 steel wool then oms. It took 4 weeks for the Howard to totally dry. Sprayed it with clear lacquer. It wasn't as shiny as original but it might have been better with beeswax. The marbling really came through nicely.
Hello Peter,
Thank you for posting that !!
Eico 232 VTVM Schematic
Try BAMA for a schematic.
Var resistor id
Var resistor id
Var resistor id
Its a Sylvania 400 oscilloscope. here is a clip of r-100. Would be nice to know the current required. Not listed in part...Martinj — 02:10 PM |
Thanks Richard. I hope you enjoy it.
Here I have created an English section on the history of radio with videos in Engl...RadioSvit — 10:23 AM |
Hello RadioSvit,
first all happy new year !
I will watch your new videos this week.
Sincerely Richardradiorich — 09:19 AM |
There are currently 9300 online users. [Complete List] » 1 Member(s) | 9299 Guest(s)
