Philco 38-116
Just finished recapping this baby and it plays great on AM, but the SW bands are dead.  Been troubleshooting for several days and believe I have a problem in the Oscillator coils section.  The bad news is I will probably have to remove the RF sub chassis.  Has anyone done this before and if so can you give me a few tips.   Thanks,
Joe Miller
Ron had a section on doing it. I believe he swapped 38-116 and 38-690 tuners, for which he did the full removal.
There are mechanical manipulation with the band switch involved.
Ii restored a 37-116 and a 38-690 without having to remove the tuner, but otherwise I can say this:
While disconnecting wires, label them all, and take plenty of photos.
