Philco G1706 Phonograph Cartridge
Dear Philco Phorum Members,
I am new to the Phorum, so please excuse me if I am posting this in the wrong area.
I have recently inherited a Philco G1706 4-speed phonograph.
The phonograph cartridge is damaged and the stylus is missing.
I am kindly requesting help in identifying replacement parts and a source to purchase from.
I would also be grateful for any other information that you may be able to provide.
Please see the attached photos.
I thank you for your time and willingness to help.
With kind regards,
Patrick (Canton, Michigan)
Welcome to the Phorum, Patrick! I'm not an authority in this area, but we have many among us. I'm sure someone will chime in. Take care and BE HEALTHY! Gary
Hi Patrick, go to this website…thevoiceofmusic.com..They have many parts, stylus, cartridges, idler wheels and more. They should be able to hook you up with what you need! I don’t have much experience with record changers but yours appears to be a VM changer.
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
Gary and Ron,
Thank you for the welcome and the advice you provided.
I contacted Gary over at thevoiceofmusic.com and he was able to provide a suitable replacement cartridge for my V-M 1201.
https://www.thevoiceofmusic.com/catalog/...?PID=P3800
Very reasonably priced.
I appreciate your talents, and I thank you for your time and willingness to help.
With kind regards,
There are currently 5640 online users. [Complete List]
» 3 Member(s) | 5637 Guest(s)
