Cannot Adjust an IF Transformer’s cores
Threads: 26
City: Monticello
State, Province, Country: Illinois
Great work, we are all looking forward to the final design.
Philco's
86 Low Boy 71B 42-321T
90 High Boy 52B 46-1203
95 High Boy 118B 48-214
112X Console 60B 48-206
118X Console 84B 49-506
41-608P Console 610B 76 High Boy
41-265 Console 37-89B 370LZ
52GC 38-35B
20 Baby Grand 38-10T
70 Baby Grand 41-221CI
Threads: 50
City: Shenandoah,
Hi Joseph, here is a great article on various types of FM detectors including the FM1000…https://www.radiomuseum.org/forumdata/users/4942/file/FM%20Alignment%20Ghirardi%201952%20OCR.pdf
Ron
Bendix 0626. RCA 8BX5. RCA T64
Philco 41-250. Philco49-500
GE 201. Philco 39-25
Philco 37-116. Philco 70
AK 35 Philco 46-350
Philco 60B. Majestic 50
Philco 52-944. AK 84
Threads: 14
City: Tulsa
Thank you for sharing! I am going to take some time to review and soak this all in.
Joseph
Philco 46-480
Philco 49-906
Threads: 14
City: Tulsa
Just a quick update, folks. The PCBs have been manufactured, and shipped yesterday. Surely they’ll arrive this week. I also just submitted an order for the connectors I will need between the two PCBs. We should have a working IF transformer by the end of the week.
Joseph
Philco 46-480
Philco 49-906
Threads: 26
City: Monticello
Awesome!!
Philco's
52GC 38-35B
Threads: 14
City: Tulsa
Threads: 43
City: Roseville, MN
Joseph, now you are an engineer!!
Threads: 14
City: Tulsa
Thank you! I was quite new to the Phorum when I started this post, so I feel like it might be advantageous to publish a summary of the process we went through in the Electrical Restoration category. I realize now that this thread should have been there, but that’s okay.
Joseph
Philco 46-480
Philco 49-906
Threads: 154
City: Westland, MI
The abilities of our 'Phorum Pholks" never ceases to amaze me! Fantastic fabrication, Joseph! I'm waiting now for your PCB solution to the FM1000 tube scarcity. Come up with that and you would make A LOT of hobbyists happy! Take care and BE HEALTHY! Gary
Threads: 26
City: Monticello
Outstanding work indeed. I wish I could come up with solutions like this.
Philco's
52GC 38-35B
Threads: 50
City: Shenandoah,
Joseph, this is beyond awesome. A lot of thought and engineering went into this and you hit a home run! Now I must save this thread for future reference. Thanks for posting!
Ron
AK 35 Philco 46-350
Threads: 14
City: Tulsa
Thank you all! It would not have been possible without the guidance of everyone who has weighed in. So far I’ve gotten about 8 hours of playtime out of the radio with the new IF transformer. It’s working great, but I’ve had to wiggle the IF can a few times because audio has gone quiet. Wiggling the can does the trick. I’m suspecting I have a bad solder joint, so I will have to pop it back open to address that.
Joseph
Philco 46-480
Philco 49-906
Threads: 14
City: Tulsa
I’ve taken the day off today, so I took a look at the IF transformer. I got lucky this time—there were no loose solder connections. The unit simply wasn’t fastened securely into the brass clip that holds it in place. This has resolved the audio issue.
Joseph
Philco 46-480
Philco 49-906
Threads: 26
City: Monticello
Congrats on the easy fix. I will bookmark this great project for future use as I’m sure many others will as well.
Philco's
52GC 38-35B
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
Welcome to the Phorum, R3Sons! I have very limited experience with car radios other than installing custom radios back ...GarySP — 01:08 PM |
OK, I need to rename this thread to say..Eico 368 TV/FM Sweep Generator instead of the current title..Heathkit Sweep Gen...462ron — 12:49 PM |
Hello, I have a Philco (Ford) 6TPZ and a 5TPO radio. I replaced the electrolytic capacitors in both. I have the SAMS m...R3Sons — 12:29 PM |
Hello Peter,
Thank you for posting that !!
Eico 232 VTVM Schematic
Try BAMA for a schematic.
There are currently 9301 online users. [Complete List] » 2 Member(s) | 9299 Guest(s)
