Philco 370LZ chair side not a 71LZ
Threads: 26
City: Monticello
State, Province, Country: Illinois
09-14-2024, 11:52 AM
Philco's
86 Low Boy 71B 42-321T
90 High Boy 52B 46-1203
95 High Boy 118B 48-214
112X Console 60B 48-206
118X Console 84B 49-506
41-608P Console 610B 76 High Boy
41-265 Console 37-89B 370LZ
52GC 38-35B
20 Baby Grand 38-10T
70 Baby Grand 41-221CI
(This post was last modified: 09-19-2024, 10:20 AM by slford310.)
Threads: 54
Are you sure that it is a model 71LZ and not the previous years' 370 Lazyboy? Production for both models appears to be 16,285, not common but not rare either. I generally try to pay as little as possible since the chassis is unknown so would try not to go above $125, maybe $150 at the top end since you want a chairside, there are others out there. Part of the beaded molding is missing, so inspect for other cabinet issues.
Threads: 26
City: Monticello
He only wants 40 so I think I’ll have to buy it
Philco's
52GC 38-35B
Threads: 26
City: Monticello
Just took a closer look at it. It is a 370LZ not the 71LZ.
Philco's
52GC 38-35B
Threads: 154
City: Westland, MI
If he only wants $40.00 what are you doing still pondering over it? Go get it! Take care and BE HEALTHY! Gary
Threads: 26
City: Monticello
lol not pondering it’s been mine for at least an hour now ?. At a local car show with my Jeep will load it up and take it home soon then I’ll post a few more pictures
Philco's
52GC 38-35B
Threads: 54
That sounds like a reasonable price, to most people it's just an old fashioned end table, apparently the cabinet was styled by Norman Bel Geddes, not that the name means much these days. Nothing wrong with a 370 Lazyboy, as long as the autodyne oscillator doesn't cause problems
(This post was last modified: 09-16-2024, 12:20 AM by Arran.)
Threads: 26
City: Monticello
Threads: 268
I'll mention a couple of fine points on the 370 that are different from the 70/70B that you currently have. The major thing is that the vol/off-on and tuning are on two concentric shafts. The original vol/off-on control is made out of unobtanium. A single resistor and pot combo (sold as a replacement) doesn't really preform same way the dual pot does.
The dial and drive has a couple of pot metal gears. Haven't seen any failures but I have seen some swelling which makes the tuning knob hard to turn. There's an easy fix which is to slightly enlarge the hole in the gear on the dial.
Your a mechanical kinda guy and I just wanted to give you a little heads up before you dive in. Oh for autodyne detector hater this set doesn't use a single tube mixer like the 80,84,89,19, and so on. It has a 24A mixer/27 lo.
https://philcoradio.com/library/download...n%2057.pdf
Threads: 26
City: Monticello
Thanks for the info Terry. Luckily for me there appears to be no swelling in the pot metal gear it rotates the tunner easily
Philco's
52GC 38-35B
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
Welcome to the Phorum, R3Sons! I have very limited experience with car radios other than installing custom radios back ...GarySP — 01:08 PM |
OK, I need to rename this thread to say..Eico 368 TV/FM Sweep Generator instead of the current title..Heathkit Sweep Gen...462ron — 12:49 PM |
Hello, I have a Philco (Ford) 6TPZ and a 5TPO radio. I replaced the electrolytic capacitors in both. I have the SAMS m...R3Sons — 12:29 PM |
Hello Peter,
Thank you for posting that !!
Eico 232 VTVM Schematic
Try BAMA for a schematic.
