Threads: 4
City: Hanover, PA
Starting on a Philco 48-1401 Boomerang radio/phonograph. It has one crack on the left side running from the speaker opening to and through the front edge. I will be able to clamp it side to side, but the crack will remain about 1/16" and will need to be filled.
I'd really like to only do this once, so I'm looking for recommendations for the best epoxy and practice to use.
I plan to finish the repair with a patch underneath using some fiberglass cloth covered with the epoxy.
I'd appreciate your feedback.
73
Bob
de371
Threads: 43
City: Roseville, MN
JB Weld. I use the 5 minute for short gaps and 30 minute for longer ones.
Threads: 54
I always used two part epoxy, the 24 hour cure stuff is stronger, it's also clear, JB Weld is usually grey. I haven't found fiberglass cloth to be necessary for repairing a crack, though it would be with filling a large chip or hole.
Threads: 8
City: Roanoke
I'm with Arran, but I use even stronger epoxy with a 72 hour cure. It is sold to knife makers for bonding wooden handles to knife tangs, eliminating the need for fasteners.
Threads: 4
City: Hanover, PA
Thanks everyone. I appreciate you sharing your experience and looks like I'll work with the 24 hr two part clear epoxy. The crack is a full break about 4 inches long. The front edge will mate perfectly but there was a loss of bakelite "dust" along the rest of the length which will keep a crack about 1/16" or less. The two part clear should help to fill it in.
