Magnetic Tuning
The last step on my restoration of a 37-690 is to get the Magnetic Tuning to work. Neither the Primary coil nor the Secondary variable cap responds to adjustment while following the alignment instructions.
Any ideas on how the can cover comes off?  The two nuts on the top are easy part, but the base is secured by a method that I am unaware of.
RJ Dial
"Radiodial"
Mendocino, CA
Welcome to the Phorum, RJ Dial! Your own photograph posted gives you the answer ... screws at the base of the can threaded to the chassis. Take care and BE HEALTHY! Gary
I think there are two pairs of pins ( you can see one in your photo) that go through the chassis. “Barbs” on the pins lock them in place under the chassis. From the underside of the chassis, squeeze the pins together so the barbs clear the holes (both sides of the cover) and that should release the cover. It’s obvious when you see it.[/i]
Greg O.
Whitehall, PA
I'm pretty sure that is not a screw in the photo, but a rivet.
I'll try and access the barbs from the underside. I'll have to put the chassis back in the rotisserie stand.
Thanks all,
RJ Dial
"Radiodial"
Mendocino, CA
Gloritone 27 Radio
Another make I have seen from U.S Radio and Television was Apex Electric, or U.S Apex, the badge on some of those had a ...Arran — 12:56 AM
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
