Philco Model 77 Parts Layout sheet
Hello all,
I am new to this forum and will be using it as a great info source for my Philco Model 77
Restoration project.
I am just starting and have restored the cabinet, now on to the chassis.
The radio I have looks fairly intact, it is missing the 2 -45 tubes, and looks like the two of 3-24s have been replaced with 58's.
I will be looking to replace all the capacitors and checking/adding tubes prior to power up!
Q. I have the schematics, but need the component layout to id the parts.
Does anyone have or know where I can get a copy of the component layout?I have checked most internet sources with no luck.
Thanks
Tony
Hi
I suggest you purchase the complete set of service information from Chuck at the Philco Repair Bench website. This will include everything you need, and the price is quite reasonable.
http://www.philcorepairbench.com/schematics.htm
Thanks for the link. I will check it out.
Chuck's service info is outstanding. Very thorough. Highly recommend! Icon_smile
Mike
Just out of curiosity which cabinet does it have?
Its a lowboy cabinet.
Picture in its original condition attached.
Note from site admin: Sorry, but the photo which was attached to this post is no longer available.
Nice!!!
There are currently 10913 online users. [Complete List]
» 3 Member(s) | 10910 Guest(s)
