Delco car radio Peko vibrator converstion issues
How about putting a choke in the power supply?
The big cap was likely an attempt to stabilize the DC. Kids who create "Boom Cars" (cars with ridiculously high powered subwoofers) do this at the amp to compensate for the long run of power cable. Without the cap, you can even see the headlights dim with each "boom".
I have not dealt with a vibrator powered radio for a really long time. The last time was in the late 70s. I was in my early 20s working on a 1957 Lincoln. The owner just wanted the car running. The radio worked the way it was. I distinctly remember the vibrator whine of a mechanical vibrator Very "spiky" similar to noise induced by brushes. I can't remember if Mom and Dad's '56 Ford made the same noise, the car rusted away in 1966 after well over 100K miles but still ran. I had worked for a guy who restored Mustangs and Lincolns, as well as selling whatever he could find and we could fix. Lincoln went to "transistor powered" by 1958, and all transistor by 1960. Ford was all-transistor by 1963.
I did fool around with a lot of car radios collected from cars discarded at the town dump. I ran the 6V ones directly from an AC transformer without modification. Sadly, I can't remember if the vibrator was noisy or not. I think so, at least on the Automatic glommed from a 57 VW (they did not go 12V till much later than American cars did, and did not convert to Alternators till much later.
I had earlier suggested replacing the 0Z4 with a 6X5, but come to think of it, Ford products in the mid 50sused typical heater type rectifier tubes, not the 0Z4, which was popular in GM sets. I still think that it would help, though.
I like the "divide and conquer" method but in addition to testing by pulling the detector / AF tube, I would reinstall and pull the IF tube. However, considering that the noise is most prevalent with the volume control full down, I think that it is carrying through the power supply to the output stage. This is why I wonder if an LC or RC filter added post-rectifier would be helpful.
Is the output push-pull? I had a radio from a 57 Chevy that was.
hello mr Fixr,
The Electro  Powersupply that I am powering the radio with has a huge choke plus a 10,000ufd electrolytic capacitor in it .
Well yes it is a Push pull I will post a photo of the powersupply /amp section of this car radio .
Hi Richard,
Thx for posting the schematic.  As I remember as a kid, these were great performers for the time, likely about 5W RMS output to the 2 6X9 speakers (one in front, one in back) that Chevy used, vs Ford's SE 12AQ5 of the period (they did have one or 2 deluxe units with 2 12AQ5 (or 2 6AQ5 in 55 and earlier), but as I remember, they were mostly Single End.
The 235hz freq of the noise makes sense as the advertised freq of the  PeKo solid state vibrator is 115hz and this is a full wave rectifier.  The issue being similar to the 120 hz hum of a full wave rectifier fed by 60Hz AC when the filter caps go bad.
I agree with the earlier statement to pull the 12AV6 and listen for the static.  If it exists at the same level, then the noise is definitely coming through the B+, and specifically, right off the rectifier, as the Plate and Screen for the 12V6s come right from the junction of the rectifier cathode, 20 uF cap and 1.2K resistor.  It does seem that they protect the filaments from switching spikes with the inductor to the radio filaments (interestingly, not to the 12V6 filaments), and the inductor feeding the primary circuit.  However, these do not filter the output of the power supply system.
In reviewing the schematics for some of the earlier Philco car radios, including the one for the 1937 Chrysler Airflow, filter chokes existed, that would filter the output tube plate and screen circuits. These did disappear by the 1950s.
The bottom line is that it is a puzzlement that a mechanical vibrator does not cause noise, but an electronic one does.  I mean, the points on these actually arc like the ignition points do.  However, putting a choke with a rather low resistance (no more than about 300 Ohm) between the rectifier plate and the filter network should help.  Maybe upping the value of the filter capacitors could help.
Attached are the specs for the 0Z4 rectifier from the RCA Receiving Tube Manual, RC14 (1940):
Interesting that this tube is pushed to its current limits, as even the idle current for 2 6V6s at 250V is 70mA.  Max current is 79mA.  Max output of a 0Z4 is 75 mA.  Note that there is a 30mA min current required for this tube to actually fire.  Also note the statement that "The use of filters may be necessary to eliminate objectionable noise".  The main use of 0Z4 as a rectifier is in car radios (and I haven't found a radio from the 1940s that use one), the main reason being that there is no filament, eliminating about 300-600mA of current draw from the battery.  This was an issue, as car radios typically draw 5-15 Amps (depending on whether 6 or 12V), and most cars had a generator capacity of no more than 30A back in the day.  Nothing like the 90A alternators of today, but back then, most cars did not have fuel injection, electronic ignition, electric fuel pumps, A/C, electric windows, rear window defoggers, load leveling suspensions, electric wipers (they were vacuum), etc.
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 10297 online users. [Complete List]
» 1 Member(s) | 10296 Guest(s)
