Philco ceramic resistors color code
Hello.
     I'm new to this Phorum and am restoring a model 96.  I have the Ray Bintliff book on Philco condensers and other parts, but have run across a couple of resistors that don't seem to be listed there.  The first one has a green body with white ends. The second one is blue with white ends and the third is yellow with white ends.  There is also a dogbone with a brown body and a yellow end and no dot. This one measures 23.9K  Can anyone please help me out with the listed values of these components?  Thanks
Tom
Photos?
This doesn't quite answer your question but might prove helpful. An annotated schematic for the 96 from our online library:
https://philcoradio.com/library/index.ph...chematics/
Info about resistors hope it helps. David   https://philcoradio.com/phorum/showthrea...#pid177816
Klondike88, your schematic answers my questions. Thanks
Tom
Icon_thumbup
Eico 232 VTVM Schematic
There are currently 3816 online users. [Complete List]
» 2 Member(s) | 3814 Guest(s)
