Threads: 562
strange. It should have more even to the GND, and the GND is 1M to the case.
Threads: 20
City: tampa
State, Province, Country: florida
Are you saying if I measure ohms from the ground lead to case it should be 1m ohms? That low resistance tells me there is a leak to ground, right?
(This post was last modified: 11-11-2024, 09:03 AM by
daveone23 .)
Threads: 562
Well, in the sch you provided (there is something missing at the very bottom, but I think it is GND), the sole connection to the case shown is the 1M resistor R31, which is used to bring the case and the GND under the same potential.
Unless I am missing something.
Of course there is a cap across that R31. And it could be bad. Or, again, we are missing something.
Threads: 20
City: tampa
I guess I need to look at r31 and C7.
Image(s)
Threads: 562
That too.
There might be other things.
Threads: 20
City: tampa
Interesting readings, r31 common ground to case bounced to 1meg on analog meter, r31 common to case bounced to 1meg. R31=1meg. Across c7, which is common to case with a parallel resistor = 40k ohms steady.
(This post was last modified: 11-13-2024, 11:41 AM by
daveone23 .)
Threads: 20
City: tampa
My resistance readings are not even close. Worried about pins 1 and 6. Even though they are off, the meter works on dc 50v and higher.
daveone23 .)
Threads: 562
Would you re-read and correct?
This does not make sense.
Threads: 562
Check all your caps. Even ceramics. I am not sure what is going on.
Threads: 562
Just occurred to me: what if you have a power transformer leak? From a, say, secondary to the case. If it is bolted to teh case.
Not sure how to better check it.
Threads: 20
City: tampa
Thats a good thought but the secondary does go to ground via R30 27k resistor.
Threads: 562
Yes.....it would connect GND to case, and you do have 1MOhm.....
I am not sure how the wiper has resistance to the case.
Threads: 20
City: tampa
From now on iam using an analog meter. R31 removed is 1 meg and c7 .01 but chassis to common is 600k. Why is that?
Threads: 562
Are you saying the Chassis to GND became LESS when you removed the R31?
And we are sure the C7 and other caps are not leaking?
Threads: 20
City: tampa
Yep, hunting down the source. Will get back to you. Thanks
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM
Hello, I have a Philco (Ford) 6TPZ and a 5TPO radio. I replaced the electrolytic capacitors in both. I have the SAMS m...R3Sons — 12:29 PM
Hello Peter,
Thank you for posting that !!
Sincerely Richardradiorich — 09:40 AM
Eico 232 VTVM Schematic
Try BAMA for a schematic.
Looks like a replacement power source for the D battery has been installed. The tube may be...Chas — 04:51 PM
There are currently 4152 online users. [Complete List ]» 2 Member(s) | 4150 Guest(s)
