Philco 41-608 changer coupler
I am working on a Philco 41-608 with the gear-driven changer.  The coupling (#35-2220) between the motor assembly and the idler wheel shaft was made of pot metal and is now in 'kit form'.
Is there a source for a ready-made replacement?  Are there any designs available for making a replacement coupler?
Thanks!
Mondial left a thread about remanufacturing this type coupler.
Hi Morzh,
I've searched using Mondial as the user name with various keywords such as 'coupler', 'motor', 'idler', 'phonograph', etc. I have not been able to find the thread you mention. Can you suggest better keywords with which to search, or another way to find that thread?
Thanks!
Alan
https://philcoradio.com/library/index.ph...38-models/
Different years but the same idea.
Thanks, Morzh.
That solves the issue of the rubber pieces. Now, I need to find a way to replicate the pot metal pieces.
Alan
3D-printing...short of machining, of course.
Or molding.
Eico 232 VTVM Schematic
There are currently 8002 online users. [Complete List]
» 1 Member(s) | 8001 Guest(s)
