Threads: 2
City: Franklin
State, Province, Country: Tennessee
Hi, I am new to the forum and excited to increase my knowledge of antique radios.
I was given this inop Philco 49-607 and would like to know where to start my troubleshooting. I powered it on through a dim bulb tester. The bulb did not light. Tube 117z3 glowed bright for a moment and went out. I did see light from other tubes and got no sound even at full volume. The label shows code 121.
I am hoping to get some guidance as I am limited on my knowledge of tube gear.
Thanks
James
Threads: 154
City: Westland, MI
Welcome to the Phorum, James! According to the information available in our Philco Radio Gallery and Philco Radio Library, your 49-607 is probably a 48-360 chassis in a 'refreshed' cabinet. Plenty of information is available in those sites located at the bottom of this page. Photographs are always helpful. It sounds like the 117z3 tube is now toast. I would recommend replacing all paper and electrolytic caps, and any out-of-tolerance resistors. I am sure others who have worked on these will help out with more information. Take care and BE HEALTHY! Gary
Threads: 562
OK, first things first: As Gary has said, do not power up, not with dim bulb, or anything else, until all the tubular/backelite/electrolytic (with the exception of the mica) capacitors are replaced, and the tubes tested.
Then you will tend to other things.
Threads: 2
City: Franklin
I found this troubleshooting guide and got 117vac at test point A and 0 at tp C. I got 0 at tp D which indicated a bad tube or switches. I cleaned the switches and the 117z3 tube socket. Still no voltage. As I said earlier, the tube lights bright when I first turn it on and then dims. This has happened several times. I have to let it be off for over an hour for it to light when I turn it on.
I will get the tube checked or get another.
Is it likely I have fried the tube at ignition?
James
Threads: 11
City: Greenlawn
State, Province, Country: NY
Hi Tennangler,
Welcome to the Philco Phorum! Lots of phine phriendly phlks phull of Philco phacts. (See a pattern here?)
Was the negative lead on test point B for all the tests? If it was ion the chassis instead, you woll get verylow readings ans this is a "warm" chassis (isolated by a cap and high resistance resistor), not a "hot "chassis (one side of AC line connected directly to the chassis).
Like Gary and Morzh said, consider replacing all capacitors, especially the electrolytics, before powering up. The electrolytic and paper caps are known to short or open. There is no need to replace the mica caps in the audio section unless you find them to be bad.
Attached below is the complete schematic for Model 49-105, similar to your 49-107.
Attached below is a blow up of the power supply.
It is common for certain tubes to glow bright and dim, and the 117Z3 is no exception. However, the tube should glow an orange to almost yellow glow, and the cathode tube should glow wen te tube settles down. It is possible that the tube get intermittent, but this is not common. Most tubes either work or fail as far as the heater goes. You can CAREFULLY check for 120V AC between pins 23 and 4 when the issue occurs. If AC is there, then the tube is bad or the socket connection is bad. If not there, then investigate S100 and S101
It is important that S100 and S101be clean or you will fail the tests in the guide that you got from the Rider manual for this set. Spray switches with Caig DeOxIt contact cleaner, but use Caig DeOxIt fader lube for the volume control. Exercise the power switch (S101) by turning on and off. Exercise the AC Battery Switch (S100) by inserting the plug into the hole on the chassis designed for it. This switches the radio to battery.
Note that the filaments of the tubes other than the rectifier are all in series and run off a 7.5V battery if the unit as on battery power. Some folks would put a 9V Zener diode across the filament supply. The most convenient spot to do so is C100D
It is important to get the wiring right with this power supply, especially the cap values and the candohm, R100. Failure to do so could cause the tubes other than the rectifier to burn out. They are all pretty common except the Audio Output Tube, 3LF4. I think that these are rather rare! Note that the tubes other than the rectifier don't really light up, even in a very dark room.
Threads: 2
City: Franklin
Thanks for the detailed explanation of how this radio works.
The 117z3 tube that was glowing each time I turned it on is no longer glowing. I may have burned it out. Will have to change those caps before I power up again.
I was putting my negative lead on test point B when checking voltages. I had already throughly cleaned those switches.
Are all the electrolitic in that big multi cap can? Looks like a big job to replace them.
I can not find the place on the chassis to plug the battery plug in.
Thanks for the replies. I will post updates.
James
Threads: 11
City: Greenlawn
Hi James,
OK, there may be more than one way to operate that switch. Whatever way yours works, exercise the switch. You can check the filament of 117Z3 by ohming between pin 3 and 4 of the tube. It should be well under 100 Ohm cold. The issue with tube filaments (and light bulb filaments) is that they are not "ohmic" devices. The hotter they get, the higher the resistance.
Hope this helps.
Threads: 11
City: Greenlawn
RE the filter cap, Yeah, these things are tight inside. I have a 46-350. Yours is similar except for the audio output tube. They can be tight. Fortunately for me, someone recapped the unit before I purchased.
Threads: 2
City: Franklin
I measured .43 kohms across pins 3 and 4.
Threads: 50
City: Shenandoah,
Just a word of caution. I don’t know if your portable is similar to a 46-350 that MrFixr mentioned, but I have the same 46-350. When pulling the chassis from the cabinet, I grabbed the electrolytic can to pull the chassis out and when I did it crumbled like an eggshell in my hand. I don’t know what kind of metal it’s made of but it wasn’t the aluminum that most were made of. It was a dull grey and very fragile! YMMV.
Ron
Bendix 0626. RCA 8BX5. RCA T64
Philco 41-250. Philco49-500
GE 201. Philco 39-25
Philco 37-116. Philco 70
AK 35 Philco 46-350
Philco 60B. Majestic 50
Philco 52-944. AK 84
Threads: 2
City: Franklin
I was able to borrow a tube tester and my 117z3 is good. It glowed when I applied voltage to it as it had in the radio. It got very hot.
All the tubes tested good except the 1u5. From what I read this is a power tube. I no I need to replace the caps but is this likely the source of no volume?
James
Threads: 562
1U5 is not a power tube. It does indeed have a diode in it, but this is a detector type and not a power rectifier.
The tube is a combined diode-pentode, that detects and amplifies.
Threads: 11
City: Greenlawn
Did the 1U5 test out at Zero? If so, the filament is open. The filaments of the various tubes except the rectifier are in series. This does not explain why the 117Z3 does not glow when in the radio; its filament across the power line after the switches. This is why I think that you have a switch issue. The 430 Ohm value for the filament of the 117Z3 is believable. Recheck the AC / Battery Switch, particularly for continuity between 3 and 6, 11 and 7, and recheck the power switch.
Threads: 2
City: Franklin
MrFixer55,
The 117z3 glowed when I tested it. It tested good. I was able to get another 1u5. So all my tubes tested good. I still get no tubes lighting and no sound.
It seems like it is not getting power. I am not sure of the numbers of the pins on the battery switch. I dont see it on the trouble shooting guide. Is there a document that shows the numbers?
Thank you
Threads: 562
The filaments are a string, so you need to check everything that is a part of that string. Any tube with bad filament, bad switch, bad contact, bad tube panel will result in no glow.
Take an ohhmeter and start with the AC plug and up.
Hello Tim,
Hello Tim,
Hi Dan,
Hello Tim,
bk1077bradiorich — 09:01 PM |
