1950 Philco Model 123 AM Radio, Antenna Terminal
Threads: 2
City: Lake Jackson
State, Province, Country: Texas
Is there a best way to use the single-screw terminal on the back of this 1950 Philco? (best antenna type, possible grounding needs, etc.). I have restored and aligned it, and works great with the loop. Any input is very appreciated.
Mark
Threads: 14
City: Tulsa
Good afternoon! Could you possibly attach a photo to show us the connector? Could you also verify the model number? 123 doesn’t sound right. It’ll probably be 50-xxx.
Joseph
Philco 46-480
Philco 49-906
(This post was last modified: 12-30-2024, 06:11 PM by jrblasde.)
Threads: 28
City: Wellborn Florida
Not a Philco but common during that time frame page 2 ant hookup. David https://philcoradio.com/phorum/showthrea...7#pid90017
Threads: 43
City: Roseville, MN
Threads: 2
City: Lake Jackson
Thanks all. Sorry about the model #. It is a 50-922, and yes, run # 123.
Threads: 2
City: Lake Jackson
Not sure how to post a picture on this site. Any advice?
Threads: 2
City: Lake Jackson
the lead for the screw terminal connects with one of the leads going directly to the internal loop antenna. Once I find out how to post a pic, I will. Many thanks....and Happy New Year everyone.
Threads: 14
City: Tulsa
To add a photo, select the black New Reply button. Type your response, and below that there is a field to either drag and drop attachments or to click if you want to navigate to the file.
Joseph
Philco 46-480
Philco 49-906
Threads: 28
Some info from Beitmans.
Threads: 2
City: Lake Jackson
Threads: 2
City: Lake Jackson
Thanks everyone. hope the pics work. and thanks for the schematic. Mine has the 50C5 aud. output and 35Y4 rect.
Threads: 2
City: Lake Jackson
I have tried only a long wire on the external terminal. Get some overloading on strong stations actually using the wire, but weak ones are strengthened. This is during the daytime.
Mark
Threads: 43
City: Roseville, MN
Your antenna is working as intended. The loop antenna is an rf transformer with the connection available for an external wire antenna. The signal on that wire brings in a stronger signal resulting in more gain to the radio.
Welcome to the Phorum, R3Sons! I have very limited experience with car radios other than installing custom radios back ...GarySP — 01:08 PM |
OK, I need to rename this thread to say..Eico 368 TV/FM Sweep Generator instead of the current title..Heathkit Sweep Gen...462ron — 12:49 PM |
Hello, I have a Philco (Ford) 6TPZ and a 5TPO radio. I replaced the electrolytic capacitors in both. I have the SAMS m...R3Sons — 12:29 PM |
Hello Peter,
Thank you for posting that !!
Eico 232 VTVM Schematic
Try BAMA for a schematic.
Var resistor id
Var resistor id
There are currently 8539 online users. [Complete List] » 3 Member(s) | 8536 Guest(s)
