Philco 49-607 inop
#31
Rod
https://www.radiomuseum.org/r/philco_49_607.html
Browse to the Photo #6.
#32
Isn't technology wonderful? A picture says a thousand words.
#33
Nah....just 13 words, counting prepositions Icon_lol
This is one step further from TO: those have it engraved on the chassis, so it is not even that visible. Until you really look.
#34
Yes, and don't try to use the polarized plug on your replacement line cord.
#35
The photo is exactly what mine looks like. See the small hole on the bottom right side of the cabinet? What is that for?
#36
A photo would help.
Rod,
of course, all the plugs I order for the portables are non-pol. Not just that, but also should have a short boot/overmold, as many plug from behind and not from the top (as in the original 7G605 T/O) and this will keep the back cover from closing. I had trouble getting one, but found a vendor eventually.
#37
I'm getting sound now but it is static sounding. Is this capacitor problems?
Does anyone have this radio and know what the hole in the side of the case is for?
James
#38
Terry (RadioRoslyn) might.
In any case, a photo of it might be nice.
#39
Hi James,
Congrats on getting as far as you have. Line / battery powered portables (Sometimes called AC-DC / Battery or 3-way powered portable radios) are one of the more complicated radios to work on due to the complexity of the power supply circuit.
Re the hole that you describe. Is it a full hole or a notch where the case joins the back cover?  If the latter, this is where the cord routes outside the case when the radio is run off house power.  If it is a hole, it may be to pass an external antenna wire into the radio.  There is a green wire with a u shaped lug that is grounded to the chassis.  Remove this connection from ground and you can connect a long wire antenna to this green wire.
This is a very sensitive radio because, unlike the typical 5 tube radio (Convertor, IF, Det / 1st AF, Output, PS Rectifier), this set has a tuned RF amplifier, like very sensitive console radios. In addition, these radios are the children or grandchildren of "farm radios" which by the rural nature of farms, had to be more sensitive than radios used in urban or suburban areas.
Are you able to receive any station over the static?  Do you have another AM radio that does not use a "loopstick" antenna to compare reception to?  In the past 20 or so years, noise pollution from CFL and LED lights, computers, WiFi, remotely read electric meters, the "Internet of Things", etc., etc., etc., have made AM reception almost impossible inside the house.  I live in a suburb of NYC with at least 20 AM stations that give a strong signal (At least 5 of these being 50KW "clear channel" stations), and I can receive only 2 of these inside my wood frame one floor single family home that has aluminum siding on only one side.  I must shut down every flat screen TV, computer, light, etc. in order to receive anything, even with a long wire antenna, unless the radio has a ferrite loopstick antenna.
The following steps are if you still have intermittent power to the radio:
If you have not done so, press that tab that operates S100, the Line / Battery switch up and down several times.  Re the power switch, take a good look at it.  There should be 4 contact lugs on the power switch, 3 contact lugs on the volume control.  There is a shield over the power switch connections to prevent electric shock, as there is no interlock for the rear cover.  This shield covers the 4 power switch lugs.  A pic from the similar 46-350 is attached below:
To clean this switch or check its continuity, you need to loosen the hex nut, slide the switch from its bracket and pry off this cover.
This is a "DPST" (Double Pole Single Throw) switch.  One "pole" of the switch switches the A-, B- and Line Power return.  The other pole switches B+.  A and B batteries are both switched so as to prevent discharge of the batteries through capacitors.  Note that for Line Power (AC or DC House Current), the "neutral" is switched.  This is one reason why you cannot use a polarized cord on these portables, as they cannot be rewired to only switch the "Hot".  The other reason is for those radios, which, like yours, require the user to plug the power plug into a "socket" which operates the Line / Battery Switch (S100 on your set).
This is what is known as a "warm chassis" set. The "ground" (common A- and B- return) is isolated from the chassis, but to pass RF, a 150KOhm resistor and 0.05uF capacitor couple the RF signal to chassis ground while limiting line current. Whether the chassis is at "ground" potential depends on the polarity of the power cord and whether the power switch is on. For example, if the switched leg (the A-, B- "ground) is connected to neutral based on how the plug is inserted into an outlet, the chassis will be at ground potential with the power switch on, but with the switch off, the chassis becomes "warm" (connected to the hot lag through the cap, resistor and the cold 117Z3 filament.
Refer to the schematic and trace the wiring as best that you can.  The AC/DC Line Power - Battery Switch is drawn in the AC/DC House Power position.
Mrfixr55,
The power cord goes out the hole in the back panel so hole on the side must be the external antenna access as you described. The internal antenna connections are next to the hole.
The static I described is more of a chattering. The stations are fairly strong. I'm in Nashville and WSM is a very strong channel. Is a chattering sound related to reception interference or a component issue?
James
#41
Does the "Chattering occur on all stations? Between stations? Does the chattering noise increase with increasing the volume control or remain the same?
Do you receive the same noise on any other radio, particularly one that does not have a ferrite loopstick antenna?
Have you recapped the radio, other than the electrolytics?
There is a phenomenon called "motorboating". This can be caused by a number of things including missing or bad B+ and cathode (filament)bypass capacitors, missing or bad AVC Cap C401 or bad negative to chassis coupling cap C402. Recap the set if you have not done so.
The chattering happens on all stations and increases as I increase the volume.
I have an old Zenith from the same era. It has the antenna on the back panel. It does not have any chatter.
I have not replaced any caps including the electrolitics.
Sounds like recapping is the only solution if I want decent sound quality. That will be a long term job for me. Wish I could check the caps inline.
Thanks for the help.
James
#43
I'm having a hard time describing the noise from the radio. When I listened to it today it did not sound like chattering. It sounds more like radio interference or a busted speaker. I did repair some cracks in the speaker. I am going to connect another speaker to see what that does. Can I connect an 8 ohm speaker temporarily?
Thanks
James
#44
Yes you can connect an 8 Ohm speaker. If the original is 3 or 4 Ohm.
Actually, if you want a bit better experiment, connect a 6 or 8 Ohm resistor in parallel to the speaker. It will make the tube happier.
#45
I connected an 8 ohm speaker to it and I still have the noise.
I also connected a long antenna wire to it and that made reception worse.
I can live with it the way it is. Dont want to spend time replacing capacitors unless I know it will get rid on the noise.
James
Eico 232 VTVM Schematic
