Philco 38-690 restoration completed
I can't believe the finish, especially the close up. Good job Icon_thumbup
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
