Safety caps
Iam looking at a safety cap with a Y4 rating. Voktage on cap says 400ac. What is the y4 rating?
When I Google searched Y4 capacitor, this definition came up...
Y capacitor sub-classes. Y4 capacitors have a rated voltage under 150 volts of alternating current (VAC) Y3 capacitors have a rated voltage from 150 up to 250 VAC. Y2 capacitors have a rated voltage from 150 up to 500 VAC and basic insulation. Y1 capacitors have a rated voltage of up to 500 VAC and double insulation.
Hope this helps. -Gary
If Y4 capacitor says 400V, it is probably because it is rated both Y4 and X1.
This will make it X-rated to, say, 400VAC, and Y-rated to, say, 125VAC.
Like this one.
https://www.mouser.com/ProductDetail/Vis...1TIQ%3D%3D
ok, misleading
>>ok, misleading
Sorry, what is misleading? The specifications, the explanations given...other? Gary pretty much has explained the rating.
Hello Martin ,
well the part from mouser is the one I keep in stock and use most often it also is small enough to fit in one the bakelite blocks too.
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 9851 online users. [Complete List]
» 2 Member(s) | 9849 Guest(s)
