Difference between Butterfly 28 and 45?
I have a butterfly and on the bottom it has the tag for a model 28, but I am still puzzled because I know other radio co. used cases from other radios and changed the chassis, here are a couple of pics If anyone can help? I would be grateful
Thanks
John
Note from site admin: Sorry, but the photos which were attached to this post are no longer available.
Hello and welcome!
Philco 28C and 45C table models are identical in appearance.
28C: http://www.philcoradio.com/gallery/1935a.htm#i
45C: http://www.philcoradio.com/gallery/1935a.htm#u
The difference? The 28 is an AC/DC set while the 45 has a power transformer, and is made for AC only.
What looks like a small black transformer in the back of your 28C is actually a filter choke. The 45 has a real power transformer in this position, and it is much larger than that choke used in the 28.
So, yours is genuine, it is a 28C.
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
