model 19
My model 19b 4 knob version came without the knobs was the tuning knob larger than the rest?
Hi Zinzer,
Yes, the tuning knob is about 1-1/4" in diameter and the rest are about 7/8".
M R Radios   C M Tubes
Thank
I thought so but its hard to tell in pictures bought three small ones on ebay now to find the big one.
Vinzer
There are currently 10595 online users. [Complete List]
» 1 Member(s) | 10594 Guest(s)
