model 84
What color toners should be used on front of 1934 model 84?
Assuming you mean this one:
http://www.philcoradio.com/gallery/1934.htm#o
Center - Blonde
Edges and bottom trim - Extra Dark Walnut
Remainder of cabinet - Medium Walnut
What a great Phorum you can find anything you need know about any philco radio here.
Thanks again
We do our best. (I mean the collective Phorum membership when I say we.)
Ron's the man!! Icon_clap
Happily back in Illinois..not.
There are currently 9921 online users. [Complete List]
» 1 Member(s) | 9920 Guest(s)
