Model 20 Consolette Resto
#46
The Admiral sounds good. It just has two wires they would take the place of the field coil.
If it is too small inductance wise you well still have some 60cy hum. Any inductor is going to be better than a resistor. If it is too small current wise it will run hot.
Ok. I will let you know how it turns out. Thanks for the advice. Icon_biggrin
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
