Source for philco rubber washers for tuning caps
I have a Philco chassis model 319[Canadian] code 123... I would like a source for the rubber washers that hold the tuning caps in place.
I did check various sites but can't seem to find the right one. I know someone here has the answers for me.. thanks Dan
   Living in Calgary Alberta
Renovatedradios.com has a lot of high quality rubber bushings and grommets and many are designed for Philcos:
http://www.renovatedradios.com/parts.html
Thank you John,,it looks like they have what I need. I will order some...
There are currently 10956 online users. [Complete List]
» 3 Member(s) | 10953 Guest(s)
